Well have triple checked everything, gone back through 4 thousand
setup vids and same ending.
Seams all N/C switches show tripped at mach4 boot up?
I'm just going to live with it till I hear back from Warp9 and Artsoft, everything works fine, homes fine, all limits trip fine.
Now off onto my next Issue with understanding how touch pad's work? did pickup a sienci pad back when I was reducing my bank account on this upgrade, and was playing with it today with no luck.
Doesn't one of the ends of contact need to be isolated from each other as there is continuity between the work piece and the tool through the mill itself? May just glue some thin plexiglass to the surfaces and add that to the thickness?
Oh and a good brain fart.... went through all my endmill sizes and ordered the appropriate collet's for the TTS tooling I ordered, doesn't help much when you neglect to order the shank size of the tooling but instead order the cutter size
More research, more reading, more video watching,
One day soon !!!! Least it moves when and where I tell it.... light at the end of the tunnel
