Hello Guest it is December 22, 2024, 12:30:16 AM
Author Topic: Jog mode reverts to constant when reset button used.  (Read 15708 times)
« on: April 17, 2023, 10:32:31 AM »
I have three machines running mach3 and one of them will revert the jog mode to constant any time either mach3 is restarted or the e stop is used manually on the controller or the reset button in the software.
Two of the machines remain on the jog mode you set it on forever unless you change it.  This is very annoying to me and I wonder.
Is there a setting for this in mach that I just  can't find?
John
Re: Jog mode reverts to constant when reset button used.
« Reply #1 on: April 26, 2023, 03:12:50 PM »
Bumping this issue hoping someone has an answer
John
