Hello Guest it is July 01, 2025, 06:59:09 AM
Author Topic: GOTO Z problem  (Read 20552 times)
Offline Roi
  •  3 3
GOTO Z problem
« on: June 14, 2023, 08:04:44 AM »
I am nearly finished with my CNC-Mill and now got a problem.
I'm using Mach3 Version3.043
I was able to get everything started and Jogging and Homing works fine.
My X-Axis counts positive when jogging from left to right - the Homing Switch on the left side.
My Y-Axis counts positive when jogging from back to front - the Homing Switch on the back side.
My Z-Axis counts negative when jogging from up to down - the Homing Switch on the up side.
When I click on GOTO Z button, X and Y axes go to the right position and Z add distance.
See video - https://youtu.be/9rlcvkKHwGA
( for example – Starting position: X3Y3Z3 => click on GOTO Z => X0Y0Z6 => click on GOTO Z => X0Y0Z12 => click on GOTO Z => X0Y0Z24…..)
- I tried to change DirLowActive in Ports and Pins.
- I tried to change reversed and Home Neg in Home/Limits.
- I tried to update Mach3 Version from 3.041 to 3.043
Nothing works…
Please advise :-\
Thanks for yours help!
Offline TPS
  •  2,594 2,594
Re: GOTO Z problem
« Reply #1 on: June 15, 2023, 03:00:15 AM »
what is selected at
Config -> Safe_Z settings ?
Offline Roi
  •  3 3
Re: GOTO Z problem
« Reply #2 on: June 15, 2023, 03:31:32 AM »
unchecked that already
Offline TPS
  •  2,594 2,594
Re: GOTO Z problem
« Reply #3 on: June 15, 2023, 05:10:01 AM »
that was the only idea i had, seems to be ok.
witch motion controller are you using?
Offline Roi
  •  3 3
Re: GOTO Z problem
« Reply #4 on: June 15, 2023, 09:32:07 AM »
Problem solved  8).
I'm using BL-USBMach V2 controller.
I update the driver for the controller ( I put BL-UsbMach-V22.dll in Mach3/PlugIns) and it solved the problem.
