Hello Guest it is December 21, 2024, 09:01:54 AM
Author Topic: File name display (noob question)  (Read 4913 times)
« on: June 28, 2023, 09:49:49 AM »
Hello all.
I use mach 3 on my 3 axis cnc and I have a number of different files I run.
 Problem: I cannot see which program I am currently running because the full file path takes up the space in the file name window. For examble: " C":\documents and settings\administrator\ bureaublad\ fol" and thats it. What can I do to make to actual file name visible? Put my g-code in the root folder? Can I tell Mach 3 to align the test right? Use smaller font?
Your help is greatly appreciated.
thanks, Maarten
Offline TPS
  •  2,536 2,536
Re: File name display (noob question)
« Reply #1 on: June 28, 2023, 12:17:22 PM »
you can use a screen designer like MachScreen and put a copy of the filetextline into the
bottom aeria and enlarge it over the complete width.
is the easyest way i think.
« Reply #2 on: June 28, 2023, 01:27:43 PM »
Thanks, TPS.
I once tried make my own screen and gave up after an hour because I could not get it to work. So I am trying to get an easy fix now.
groeten, Maarten
Offline TPS
  •  2,536 2,536
« Reply #3 on: June 29, 2023, 02:01:01 AM »
have you used MachScreen to modify your screenset?
https://kd-dietz.com/pages/eng/machscreen/description.html
it is quite simple to use.
« Reply #4 on: June 29, 2023, 04:10:53 AM »
Hi, I did try, but I could not find a way to display filename with the Dietz screen designer. Also, it has no tool path display. (that I could find).
Mach3screen is nowhere to be found. Not on my computer and not on the current mach3 download, not on the newfangled site.
Screen4 is an .xml file that I cannot figure out how to get started. So thats why I was looking for an easy solution.
But indeed I would love to have everything I need on one screen in stead of having to switch screens.
regards, Maarten
Offline TPS
  •  2,536 2,536
« Reply #5 on: June 29, 2023, 04:44:33 AM »
you have to run download Machscreen and put it into a folder.
then run Machscreen
then ->File ->open file -> C:\Mach3\1024.set (if you use standard screenset)
now can see page 1 from screenset.
select the filedisplay textbox and shift it to the bottom
expand it to the comple width
save file
done
there are also a lot tutorials on youtube.
for example: https://www.youtube.com/watch?v=X9qYrQlYS8I
« Last Edit: June 29, 2023, 04:48:49 AM by TPS »
  •  9,279 9,279
« Reply #6 on: June 29, 2023, 05:11:02 AM »
Mach3 screen designers can be downloaded from the bottom of this page;
https://www.machsupport.com/downloads-updates/mach3-downloads/
« Reply #7 on: June 29, 2023, 06:26:49 AM »
Hi, that was will hidden.
I manages to make a screen with just what I need all on one screen.
Thanks for the help
Maarten
