Hello Guest it is September 27, 2026, 10:28:34 AM
Author Topic: ref all home problem  (Read 44699 times)
« on: July 11, 2023, 08:23:51 AM »
Hey Guys
I'm looking for a little help. I'm pretty much finished building my 3 axis cnc router. I've got my steppers all set up properly I think, I'm sure there be some fine tuning once I start cutting. I'm having a hell of a time trying to get ref all and homing thing going. When I hit the ref all it starts with the y axis activates the switch and stops. I believe its suppose to bounce off it and start the next axis. So I have Mach3 USB and  2 limit switches on each axis, they are all connected to input #1 on the board. In ports and pins I have +,-,and home on all 3 axis enabled to port 3 and pin 1. So hit 1 and they all light up in Diagnostics but they work. Is this were my problem is? I'm wondering.
Also the zero buttons are not the same Y is red, X is red, Z green
I've come a long way, just seeing the motors move brings a smile to my face, cant wait to get it cutting
So thanks in advance any and all help would be greatly appreciated
Have a great day
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: ref all home problem
« Reply #1 on: July 11, 2023, 02:02:23 PM »
I would start by putting a value of 500 in the de-bounce box in general config and see if it helps, if it works then you can reduce the value until it fails and then pick a value 10% above.
« Reply #2 on: July 11, 2023, 03:01:44 PM »
Hey Graham
so I tried that and it still just freezes on the first limit switch not sure what's going on
thanks for your help
  •  2,785 2,785
« Reply #3 on: July 11, 2023, 03:39:05 PM »
Disable limits in ports and pins and see if it will home.
« Reply #4 on: July 11, 2023, 05:32:52 PM »
Hey Graham
So I turned off the limit switches and the ref home does nothing. I can set and go to zero fine
  •  2,785 2,785
« Reply #5 on: July 11, 2023, 06:58:48 PM »
What breakout board/motion controller are you using?
  •  2,785 2,785
« Reply #6 on: July 11, 2023, 07:17:26 PM »
It might be best to have the home switches on a separate input wired normally closed in series and forget the limit switches for now.  Limit switches are usually wired through the e-stop circuit.  So you would have 3 switches per axis.
« Reply #7 on: July 11, 2023, 07:19:11 PM »
its the red board with step and dir for 4 axis on the top and 24v power down the side with 4 inputs and 4 outputs 100khz usb
« Reply #8 on: July 11, 2023, 07:28:13 PM »
thanks for all your help Graham
I will try that in the morning and post the results it time to call it a night my brains on overload lol
  •  2,785 2,785
« Reply #9 on: July 11, 2023, 07:30:34 PM »
I hope you are not using the pirate Mach3 & licence file that they provide!!
If you are then get rid and download the demo version from the web site, remove and replace then start setup again.
We do not usually help people that use this type of board due to the piracy issue.
