Good evening,
I am running a licensed version of mach 3.043. I am building a plasma table with 4 nema 23 motors. I have an X, Y, Z, and A. I have wired everything according to the driver specs (Please see attached document). I am using 4 DM542T motor drivers. my BOB is a DAOKI 12-24V CNC breakout board 5 axis Mach 3 interface board with optical coupler board. (it was cheap on amazon and I am starting to think I need to get a different one) In the setup of the motor and pins, I have selected the corresponding pins to my BOB. X:Step(2) Dir(3) Y:S(4)D(5) Z:S(6)D(7) and A:S(8)D(9). I click apply and then go on to setup my other outputs/limits etc. When I jog the machine I am able to get movement in both directions of all motors except every motor's axis is switched. The X button controls my Z motor, Y button controls A motor, Z button controls X motor and A(4?) button controls the Y motor. Now I went back into the ports and pins menu and changed them to reflect the motors they are controlling. X: Step(6) Dir(7) Y:S(2)D(3) Z:S(8)D(9) and A:S(4)D(5). I then clicked apply and ok. There was no change in motor output control. I dug into some forums and it was advised to delete all the XLM files and reconfigure the ports and pins. I did so and it had no change. I also restarted the Program and the PC. I also went as far as completely uninstalling and reinstalling mach 3 from a fresh download off of the website. I did this twice. I even restarted the computer when I installed the software and the Parallel port driver per the setup instructions. This time upon starting up and after configuring my pins. The motors are still incorrect but now the X,Y,Z,A jog buttons control a different, incorrect motor.
Also, on a related note, I have setup the Slave axis X:A. I noticed that when I get the physical X motor to run (labeled Z in mach 3) no other motor runs. In fact when I run all of the motors individually, there is not an instance where two motors ever run at the same time. I am at a loss and unable to figure out what is going on.
I am running a Dell optiplex 390 with a PCI-E card. Windows 7 32 bit. Card voltage should not be an issue as the BOB is supplied by its own 5V power supply. I have checked and rechecked and checked all the wiring. I am even running shielded cable for all of the step/dir wires as well as the motor leads. I have also checked the parallel port for continuity - all pins match up. One thing that I can think up that in some way could be interfering is that when I downloaded mach 3 to a fresh windows 7 computer the application would cause the computer to crash. I started deleting updates in chunks of 4 until I got it so I could run the program without it crashing. Maybe there is something there, maybe not. I have no idea. I am brand new to this and learning as I go. Any help would be greatly appreciated.
