Hello Guest it is December 26, 2024, 11:01:15 PM
Author Topic: How to set x,y,z,a and c when posting from Fusion 360  (Read 4748 times)
« on: December 16, 2023, 09:55:16 PM »
How to set x,y,z,a and c when posting from Fusion 360. In the following sample post, Y is set to -300. The Machine Definition Kinematics is set as From coordinate Limited  0 mm min to Max 300mm. Why does the post: G0 X1.002 Y-300. ??
(MACHINE)
(  VENDOR AUTODESK)
(  MODEL GENERIC 5-AXIS AC TABLE-TABLE)
(  DESCRIPTION THIS MACHINE HAS YXAC AXIS ON THE TABLE AND Z AXIS ON THE HEAD)
(T3 D=4.572 CR=0. TAPER=118DEG - DRILL)
(T4 D=5.953 CR=0. TAPER=118DEG - DRILL)
(T5 D=7.938 CR=0. TAPER=90DEG - SPOT DRILL)
(T6 D=7.62 CR=0. - FORM MILL)
(T11 D=3.175 CR=0. - FLAT END MILL)
(T12 D=4.762 CR=0. - FLAT END MILL)
G90 G94 G91.1 G40 G49 G17
G21
G28 G91 Z0.
G90
(ROTARY PARALLEL2)
T12 M6
S5000 M3
G17 G90 G94
G54
G0 A90. C89.993
M8
G0 X1.002 Y-300.
G43 Z316.988 H12
G0 A90. C89.993
X0.999 Z316.989 C90.
X0.484 Z308.222
G1 X0.462 Z307.845 F167.
Z306.191
X0.448 Z306.077 F191.
X0.403 Z305.962
X0.327 Z305.86
X0.227 Z305.781
X0.114 Z305.732
X0. Z305.715
Z305.71 C-88.813 F501.
Z305.715 C-265.827
C-270.
Y-302.381
Z305.712 C-91.
Z305.715 C86.116
C90.
Y-304.762
Z305.712 C-89.
Z305.715 C-266.116
C-270.
Y-307.144
Z305.712 C-91.
Z305.715 C86.116
C90.
Y-307.707
Y-307.764 Z305.706
Offline Graham Waterworth
  •  2,747 2,747
  • Yorkshire Dales, England
Re: How to set x,y,z,a and c when posting from Fusion 360
« Reply #1 on: December 17, 2023, 10:18:19 AM »
Move the datum point of the model to the datum point in Fusion that matches your machine.
