Hello Guest it is December 21, 2024, 08:49:34 AM
Author Topic: Mach3 window resizing does not resize the screen also  (Read 3116 times)
« on: March 06, 2024, 05:46:48 AM »
Hello,
when Mach3 is resizing the screen inside does not resize as well..do you know a solution for this ?
regards
  •  9,279 9,279
Re: Mach3 window resizing does not resize the screen also
« Reply #1 on: March 06, 2024, 06:06:46 AM »
Resize the screen then close Mach3.
Restart Mach3.
New size displayed.
« Reply #2 on: March 06, 2024, 06:17:11 AM »
You din't understand my question..
When I open Mach3 it usually opens maximized..but if I resize the Mach3 then the screen stays the same size (maximized, instead of resizing accordingly so that you can see it entirely)
  •  9,279 9,279
« Reply #3 on: March 06, 2024, 08:54:41 AM »
Restore Down before resizing the screen.
Also check Auto Screen Enlarge in General Configuration Dialog.
« Last Edit: March 06, 2024, 09:12:02 AM by Tweakie.CNC »
