Hello Guest it is September 21, 2026, 06:02:28 AM
Author Topic: Spindle Setup with 7866 control and VFD  (Read 120403 times)
« on: March 18, 2024, 08:10:36 PM »
I'm setting up my servo spindle with 0-10V control.  I have the quadrature encoder wired in, so I wanted to know if there is any need to wire in the outputs from the VFD for "Speed reach" and "zero speed" since the control is using the encoder it should already know?
It also has a "warn output" which I'm guessing is to let the control know if there is an issue with the VFD.  How would I go about wiring this in correctly?
Thanks!
Mike
Re: Spindle Setup with 7866 control and VFD
« Reply #1 on: March 23, 2024, 09:11:21 AM »
Since Mach has those inputs I'm going to go ahead and wire them in and use them.
« Reply #2 on: September 08, 2024, 10:43:13 PM »
I've got another question on this subject. Is there a way to have Hicon and/or Mach4 auto-adjust the voltage to keep the spindle speed at the set speed? I got my spindle running tonight finally. I noticed that the actual speed is a bit lower than the commanded speed. It's setup as 0-10V with an encoder that appears to work correctly.
This is the spindle and driver I have:
https://www.automationtechnologiesinc.com/products-page/featured-cnc-products/milling-spindle-motor-and-inverter
