Hello Guest it is September 14, 2026, 01:32:57 PM
Author Topic: Mach 3 and Fusion 360 Radius Cutting  (Read 56561 times)
« on: August 14, 2024, 08:20:57 AM »
Hi all,
I hope there is someone here that can offer a little advice!
I've recently started using Fusion 360 to do a little design work and I'm struggling to get the thing to output a code to cut a radius.
I'm using the generic post processer from the Fusion website. The machine cuts the part fine apart from the radii. The code seems to tell the machine to cut the radius in 1 full circle. See the attached image.
Is there a simple solution to this or is there something glaringly obvious in the setting somewhere that I haven't spotted?
Thanks to anyone who can help in advance!
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Mach 3 and Fusion 360 Radius Cutting
« Reply #1 on: August 15, 2024, 06:34:09 PM »
Change it IJ mode in Mach config or reverse arcs.
