Hello
Guest
it is
March 12, 2025, 12:28:28 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Mach4Plasma stops on M3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach4Plasma stops on M3 (Read 4924 times)
fwhitt
3
on:
August 14, 2024, 12:52:15 PM »
Hi all,
Needs some help with Mach4, I've been using Mach3 for years and my old pc went down so decided to upgrade the controller and the PC at the same time. I'm using Pokeys57CNC control along with there PlasmaSens THC. I have everything moving and setup per the documents but I'm having an issue where when starting a cut it will go down and probe then return to cut height, fire the torch and will not move any farther. I've included a onedrive link below of the problem and was hoping someone could help me. I've also include the Gcode and my M3 macro (mach4 original) I'm thinking its a setting in Mach that I'm missing because I can delete the M3 macro from the folder and it moves forward and cuts with no issue, it just doesn't probe. I'm using build 5454, I know its a developer version but I'm having the same issue on the 5036 version. Thank you in advance.
https://1drv.ms/v/s!ArNfmDicjobYiblEDNnjcesXVk-uWg?e=cgu2V0
Last Edit: August 14, 2024, 12:59:58 PM by fwhitt
fwhitt
3
Re: Mach4Plasma stops on M3
Reply #1 on:
August 15, 2024, 12:39:55 PM »
No advise from anyone?
TPS
2,558
Reply #2 on:
August 18, 2024, 03:07:33 AM »
looks like machine is waiting for THC on signal
Last Edit: August 18, 2024, 03:09:10 AM by TPS
fwhitt
3
Reply #3 on:
August 18, 2024, 05:17:17 PM »
thank you for your reply. I bought Mach4 and wish i hadn't. It's no where near ready in my opinion. I just reinstalled Mach3, set everything up and it's working great.
Print
Pages:
1
Go Up
« previous
next »
