I am running version 4.2.0.4612. What build number changed from version 1 to version 2? If I go to the latest build, are my macros compatible wiht the new version? Everything works fine except my ShuttlePro MPG. The jog function is erratic and has caused me to break bits
As you are already using V2 then I am sure that all your existing macros will be compatible with the latest Mach4 build.
However, Mach4 build 5000 onwards had some major changes which affected the operation of many Motion Controllers, some of which have still not yet been fully resolved. Just for example, problems have been reported on the forum of issues with the PWM generation for spindle speed control with the Warp9 plugin and backlash compensation issues with the CNC Drive plugin. Whilst I am sure that the manufacturers of these motion controllers are working on it and will resolve any problems it all takes time.
Just out of curiosity, are you using the ‘Contour’ or the ‘XHC’ ShuttlePro ?
