Hello
Guest
it is
February 05, 2025, 12:06:11 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
cnc lathe question
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: cnc lathe question (Read 1725 times)
johndolecki
78
cnc lathe question
on:
December 22, 2024, 06:56:15 PM »
I understand the two lathe axis.
X and Z
If I want to use the spindle to drill 4 equally spaced holes with live tooling.
Is it still called the spindle or is there an axis definition that the lathe knows that I’m using the spindle for positioning?
Last Edit: December 22, 2024, 07:02:34 PM by johndolecki
Logged
JohnHaine
915
Re: cnc lathe question
Reply #1 on:
December 23, 2024, 04:46:24 PM »
Do you have a servo spindle? You mean holes on a pitch circle? I think there might be a C axis but I'm not sure if Mach supports it.
Logged
Print
Pages:
1
Go Up
« previous
next »
