Hello Guest it is September 20, 2026, 11:47:39 PM
Author Topic: Power Supply Voltage Too High  (Read 23690 times)
Offline olf20
  •  325 325
Re: Power Supply Voltage Too High
« Reply #10 on: December 01, 2007, 01:40:18 PM »
Overloaded, I built my own power supply from a micro wave transformer. It was real easy.
Tear out the secondary windings (a little care not to hit the primarys). Keep the paper / insulation
out of the secondarys. I used #10 stranded. I wrapped 4 turns, measured the voltage. Calculated
the number of turns to get the voltage that I wanted. Wound the wire, and secured the secondary
windings with hot glue. Everything has worked great! I may have $15 in the power supply. Some say
that this type of transformer will get hot when running continously, but I'm running a 3 axis mill (2 motors
1220 oz, and one 600) and have had no trouble at all.
Just some idea's
olf20
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
« Reply #11 on: December 01, 2007, 07:56:15 PM »
Looking forward to seeing those pics (or video  ;) ) Chad and as usual, glad to see ya.
