Hello Guest it is September 09, 2026, 09:01:49 AM
Author Topic: Contol of 4th Axis  (Read 9648 times)
Contol of 4th Axis
« on: December 03, 2007, 05:38:00 AM »
Hi
I am planning to make camshafts for model ic engine. and would like to use rotary table to mill lobes.
How do I contol the 4th axis by degrees,  i.e. make a cut in Y direction, return, rotate table 10 deg make next Y cut and so on.
Thought of useing gear cut wizard but can't figure a way of adapting it.
Anyone got any thoughts? Thanks
Mike
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Contol of 4th Axis
« Reply #1 on: December 05, 2007, 05:34:15 PM »
like this
G00 G90 X0 Y-20. A0 Z25.
Z0
G01 Y20. F10.
G00 Y-20.
A10. (ROTATE 10 DEGREES)
G01 Y20.
Graham.
« Reply #2 on: December 07, 2007, 03:46:36 AM »
Hi Graham
Thanks for info. have now got A axis under control.
Do you have any experiance with VFD's? as having problems pogamming one
Mike
