Hello
Guest
it is
December 21, 2024, 10:49:31 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Probe normally open/close?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Probe normally open/close? (Read 4625 times)
TT350
113
on:
December 16, 2007, 09:39:18 PM »
Hi guys I wired a probe into Mach3 today.
When I tested my probe I found that it needs
to be normally open.
My probe is normally closed,
How and where do configure Mach to work with
this probe.
Chris
Logged
Chaoticone
5,624
Precision Chaos
Re: Probe normally open/close?
Reply #1 on:
December 16, 2007, 09:44:22 PM »
Config, ports and pins, inputs. Scroll down till you see probe and change tha active low. If it is a red x, click on it to change it to a green check. Click OK at the bottom and exit.
Logged
If you could see the things I have in my head, you would be laughing too.
TT350
113
Reply #2 on:
December 16, 2007, 11:27:39 PM »
I'll play around with it tomorrow and let you know how it works thanks !
Chris
Logged
stirling
2,188
UK
Reply #3 on:
December 17, 2007, 08:21:20 AM »
Mach's probe default is active high (a cross in active low) which is correct for a NC probe, which is what you say you have, so something doesn't seem to add up here unless you've already changed it in ports n pins.
Last Edit: December 17, 2007, 08:28:31 AM by stirling
Logged
Razordance Torch Height Control
TT350
113
Reply #4 on:
December 18, 2007, 08:14:42 AM »
Thanks for the quick response guys, it works!!
Logged
Print
Pages:
1
Go Up
« previous
next »
