Hello Guest it is September 22, 2026, 04:06:51 PM
Author Topic: HELP!!! with LPT3 port  (Read 34276 times)
Re: HELP!!! with LPT3 port
« Reply #10 on: January 02, 2008, 05:23:40 PM »
Your port information should be in "system Information" if your using XP.
Go to:- Start-
           Programs-
           Accessories-
           System Tools-
           System Information-
           Components-
           Ports-
           Parallel.
You should then find the port address
Jim
Offline Heian
  •  13 13
« Reply #11 on: January 02, 2008, 06:00:57 PM »
Thanks Jim, I found the info there thats looks much more like the info that i needed, 9c00 address, I changed it in Mach but i have no way to test the port tonight, i brought the computer home because i thought i was in for a long night. Unless you guys have some way to test it otherwise. Thanks to both you and Hood for your Help on this matter.
Best Jp
« Reply #12 on: January 02, 2008, 06:08:03 PM »
Hood,
I tried what you suggested and it didn't work. One of the problems I'm had was the number I put into the port setting was not what you showed. What I have under resources type (I/O range setting (FCF8-FCFF) I am using a Quatech SPPXP-100 Express card in the LPT3 port. As you can see all I have is letters basicly... any help would be appreciated... Thanks
John
« Reply #13 on: January 02, 2008, 06:47:54 PM »
John, I have sent you a personal message.
« Reply #14 on: January 02, 2008, 11:54:56 PM »
John
 Brett has probably got you sorted but if not then you want to put FCF8 as your port address.
jp
 You could put a voltmeter on one of the pins to ground and set it up in ports and pins and toggle it High/Low and you should see the voltage change.
Offline Heian
  •  13 13
« Reply #15 on: January 03, 2008, 09:54:49 AM »
Well i got a brakeout board conected to port 2 and its lighting up like a Christmass tree. Thanks again to all. Jp
My Next mach Project is going to be a cinnn Mill 160 v with a 21 position rotary tool  changer. Im sure i will be back on soon.
« Reply #16 on: January 03, 2008, 12:17:17 PM »
Sounds like a nice project :)
« Reply #17 on: May 16, 2008, 02:56:39 PM »
Glad you got sorted.
Jim.
