Okay.
I down load version 1.90.029 and when it open it did not fit the screen , the emergency bottom was on (it was the e-stop, y active low and when off) and the Time in Interrupt was working and then it stop . The test Diagnostist apparently works okay but doesn't show nothing in the little screen and the native unit was in inches, i check mm and would not change it.
Hugo C.
