Hello Guest it is April 02, 2025, 05:37:49 AM
Author Topic: PCB's with Mach  (Read 46690 times)
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: PCB's with Mach
« Reply #10 on: February 01, 2008, 01:25:14 PM »
While waiting for components I was messing around with adding a silkscreen to the component side of the board. After searching the web I found that some folks reported having great success laser printing on Staples "photo basic gloss" inkjet paper (#item# 648181, $20 for 50 8.5"x11"sheets). I mirrored the silkscreen and printed it onto a half sheet of the Staples paper, lined up the printout face down on the top of my board and then used cloths iron to transfer the toner to the board. There is a lot of information about the process here: http://www.fullnet.com/~tomg/gooteepc.htm
I'm pretty happy with the results although I wish I had gotten it aligned better on my board.
Happy machining , Jeff Birt
Re: PCB's with Mach
« Reply #11 on: September 03, 2013, 08:02:46 PM »
we are also make some research about PCB bits, thank you for the helpful info here  :)
Good cnc router bits, end mill cutter factory.
http://www.astech-cnctools.com/
