Hello Guest it is October 03, 2026, 12:56:43 AM
Author Topic: Mach Spindle Load Meter.  (Read 22494 times)
« on: November 27, 2005, 07:23:05 PM »
Hi Guys
Just finished signing up and reading all the interesting posts.  Man, this CNC stuff is exciting. Can't get enough of it.
I do have a question on installing a Load Meter for the Spindle Motor and having it show up in Mach.  I am planning to use a 3 phase Motor and a VFD.  From what I have found so far, most of the VFD's do not have any type of output signal for the amount of currant the Motor is drawing?  I will also be using a Peter H. IOMod Board if this would help?  Has anyone installed a Spindle Load Meter?  Thanks for the help.
Regards
WillyB
Re: Mach Spindle Load Meter.
« Reply #1 on: November 27, 2005, 10:09:58 PM »
When I did the video I had it running from the drive (0-10VDC) to the PLC. The PLC was set up with modbus and Mach was taking  the value into the macro pump... please check out the video on macropumps :) I told a bit about it in there..
Peter's ModIO should work very well for this as well.
Brian
www.newfangledsolutions.com
www.machsupport.com
