Hello Guest it is November 27, 2026, 09:23:15 PM
Author Topic: Pacific Scientific Drives  (Read 16311 times)
descore
« on: May 02, 2006, 10:35:37 AM »
I am building a new cnc router using pacific scientific drives and motors. I'm using a Sound Logic breakout board to connect everything. My P70360 drives have 4 pins for step and direction. Step +, Step -, Dir + and Dir -. Mach3 and the breakout board only have one step and one direction input. Any input on how to wire this would be appreciated.
Re: Pacific Scientific Drives
« Reply #1 on: May 02, 2006, 10:49:22 AM »
In the past i have used : http://www.usdigital.com/products/ea/   EA-D10 with the W5 Opt.
That should get you up and running!
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: May 02, 2006, 03:04:37 PM »
Cant you just hook up the output of your breakout board to the + terminal, and connect the - terminal to ground?
Dont know if that would work though
Regards
Fernando
descore
« Reply #3 on: May 07, 2006, 02:22:35 PM »
I connected the step- and dir- to the common terminal on my breakout board and the step+ and dir+ to the step and dir terminals. Works great!
