I'm trying to make sure I understand how FEEDHOLD works.
Sometimes when I"m cutting a sign, I'll run a second file with a smaller bit. Even though I zero the Z before running the file, sometimes I need to stop the file, adjust the Z depth, and then resume.
To do this, I should
1) Click FEEDHOLD
2) Move the Z axis to some piece of material surface that is at start, or Zero height.
3) Jog the Z axis down to the surface or deeper as needed (router still spinning)
4) Push the Z axis DRO to re-zero at the new corrected depth
5) Push Cycle Start and watch the Z axis return to the point stored by the Feedhold click and resume cutting, but this time from the new Z Zero reference point.
Is this correct? Is there an easier way? Thinking out loud, can I input a Gcode depth correction as an MDI and then resume? And what is that proceed from box for?
Lot of questions for someone from Washington State.
Thanks in advance
WayneC
Mach 3 on an upgraded Shopbot with Ascension controller.
