Hello Guest it is September 29, 2026, 04:12:31 PM
Author Topic: PCB making  (Read 23260 times)
PCB making
« on: May 12, 2006, 03:30:09 AM »
Hello everybody. Does anyone know software, which can generate G-code for PCB making? I know, some companies produce CNC milling machines with PCB making capabilities, and they offer software for this job. Unfortunately price for such program product is too high for “backyard hobbyist”.
I will be appreciating for any good advices.
Vladimir
ynneb
Re: PCB making
« Reply #1 on: May 14, 2006, 05:56:38 PM »
This is a link to a freewareversion of Eagle http://www.cadsoft.de/freeware.htm
It does have some size limitations, but you can upgrade to a fullware version for $199
is this what you were thinking of ?
Re: PCB making
« Reply #2 on: May 15, 2006, 02:03:49 AM »
Thank you for reply. Unfortunately Eagle PCB software produces CAM file for PCB manufacturers, but not engraving. I tried downloading CAM file, which the software produce and only drilling points and pads were available for engraving. The best thing I found online is   TechSoft PCB Making (http://www.techsoftuk.co.uk/techsoft_software.htm).  But, it is still quite expensive for me and I don’t know how download an export file to Mach 3.
Thank you anyway for support and maybe eventually you will include PCB making options in Mach.
Vladimir
ynneb
Re: PCB making
« Reply #3 on: May 15, 2006, 02:22:45 AM »
I am almost positive it can be done with eagle. Ive seen the files generated b4
Go to this new forum http://www.pminmo.com/phpBB/ and I know Phil will definately be able to sort you out. He is a really nice guy, and will look after you.
ynneb
Re: PCB making
« Reply #4 on: May 15, 2006, 03:14:21 AM »
Vlad You have given me a good idea for another video. I will show you the process of engraving a circuit board in Mach3 from a Eagle file.
I know it can be done but I guess I should learn myself first. Hold off for a day and Ill let you know the results.
ynneb
Re: PCB making
« Reply #5 on: May 15, 2006, 08:34:29 AM »
I knew I wasnt dreaming see here http://www.brusselsprout.org/PCB-Routing/
And also check out this great deal for non profit users after you read the other link http://www.cadsoft.de/nonprofit.htm
« Last Edit: May 15, 2006, 08:39:03 AM by ynneb »
Re: PCB making
« Reply #6 on: May 16, 2006, 01:16:16 AM »
Thank you for links, without doubt I will buy Eagle non –profit license in near future, but for now for me the most important buy a CAM software (Bob CAM for example) and license for Mach 3 as 1000 lines obviously will limit me for 3D machining. By the way I found a bug in Lazy CAM. When I go to File menu then Open Image File (JPG/BMP) Windows reject Lazy CAM and gives message about wrong operation.  I included message generated by Windows about this problem. When I used previous version of Mach3 without embedded Lazy Cam but with unnamed CAM software I never had such problems. What is it might be?
Vladimir
