I am trying to get my Dell Optiplex 520 / Pentium 3ghz / 2 Gig of memory / xp PRO / to run my steppers properly.
I know for a fact that it is a parallel port signal quality issue. The Nec laptop that I use works great but wanted to
upgrade the PC end of things. Looking at the parallel port signals with an oscilloscope confirmed a nice 5V clean crisp step pulse waveform out of the NEC. The Dell was a different story, both the port on motherboard and installed Rosewill RC-303 card ( and may I say thank you to the guy that posted the special drivers for the Rosewill) are not clean / do provide 5v / but there is a lot going on which explains why the steppers sound ragged. I don't want to have a basket full of cards before finding a good one.
Has anybody out there purchased a card which provides a nice clean 5v signal using a similar or same model computer?
( Dell recomended a Starteck PCI-2S1P) Anybody have experience with that card?
The following may benefit someone else on what was checked for on the DELL. I knew it was a PC signal issue but wanted to check
all the other stuff which could cause problems.
1. Sniffed the cables for possible RF influences.
2. Tried varing different power supply outlets.
3. Tried two different I/O cards ( both returned to the store, XP complient now means something to me!)
4. Optimzed the PC with exception of the Standard PC.
5. Post cloning my original hard drive to another for testing purposes, every program, one by one ( good grief there were a lot ),
was removed and MACH3 run to see if there was a possible program issue which would come to light. There were none! Made no
difference. [ security software was always turned off and were the first programs to be removed]
6. Tried every concievable motor tuning / MACH3 settings that I could play with.
7. Additional PC changes from combinations of BIOS settings, windows settings, hardware combinations disconnected,etc. All with
MACH testing done in between each. The only thing that made a slight improvement was putting it into Standard PC mode, but
nothing to write home about!
8. Reformat drive, new XP installation, MACH2.63 loaded only, optimized, ( truly stand alone PC for CNC) No difference!
9. Mach 2.6 & Mach 3.x tried . No difference!
10. And then there were things in windows that were tried that I don't wish the unknowledgable to even try. No difference.
