Have a look at the PoKey, just got one a few days ago and so far its looking good
Its nt a breakout but will be very handy for lots of extra I/O
It is a USB device that can be used to connect 55 digital Inputs or Outputs, five of which can be analogue, at the moment though Art doesnt have the analogue done in the plugin but if there is enough interest he will do it.
I have been messing around with it for the last few days, had a 12 position rotary switch hooked to it and made a small Brain up so I can set the FRO from 1% to 150% in 12 stages, it works great. If the Analogue part of the plugin is done a Pot could be used instead to give infinite FRO and only use up one of the Inputs. Each pin can be set up as either an Input, an Output or even a keystroke.
