I've done everything in this to run a via the brain. It still is not working for me. I've checked the syntax in my macro to set the trigger macro to make sure it wasn't spelled wrong. I even went through the OEMTriggers in the hotkeys and set them to 301 which runs the triggered macro. I'm using a switch to change my jog % to a UserDRO # fast or slow. My switch, left or right, is set to OEMTrigger 1 & 2. I've got it in my brain set as follows. OEMTrigger1 --> NOP --> Terminate 1034 (Execute button script). Just like it says to do in the post. Still Nothing. ANY SUGGESTIONS!!??
