Hello Guest it is March 14, 2025, 02:00:47 AM
Author Topic: How to run a Brain triggered Macro.........  (Read 51446 times)
Re: How to run a Brain triggered Macro.........
« Reply #10 on: November 27, 2012, 04:40:06 PM »
I beleive you can only have one OEM code 301 at a time.
SetTriggerMacro 35    'Macro M35.m1s
This sets Macro M35.m1s to OEM code 301.
If you want to use another you have to use another SetTriggerMacro statment
SetTriggerMacro 36 sets M36.m1s to OEM code 301.
Tony
« Reply #11 on: November 27, 2012, 10:30:02 PM »
thank you Tony, I solved my problem to activate several macros with the plugin Mad Mach. I thank everybody that gave me attention and tried to help.
« Reply #12 on: September 02, 2014, 04:48:41 PM »
I've done everything in this to run a via the brain.  It still is not working for me.  I've checked the syntax in my macro to set the trigger macro to make sure it wasn't spelled wrong.  I even went through the OEMTriggers in the hotkeys and set them to 301 which runs the triggered macro.  I'm using a switch to change my jog % to a UserDRO # fast or slow.  My switch, left or right, is set to OEMTrigger 1 & 2.  I've got it in my brain set as follows.  OEMTrigger1 --> NOP --> Terminate 1034 (Execute button script).  Just like it says to do in the post.  Still Nothing.  ANY SUGGESTIONS!!??
Chad Byrd
« Reply #13 on: January 08, 2015, 01:06:38 PM »
The forum software suggested starting a new thread as this one is old.
I did that, but wanted to stick something in here to tickle anyone who might still be subscribed.
