Hello Guest it is September 22, 2026, 01:59:24 AM
Author Topic: Screen adjustment  (Read 13625 times)
Screen adjustment
« on: June 26, 2008, 11:05:21 AM »
Hi guys,
when i load a g-code the screen with the toolpath shows up normally.
the problem is that if i zoom on it, after i edit the program the screen will unzoom and go back to normal position.
Is there a way to keep the toolpath zoomed as you prefere everytime?
thanks
Re: Screen adjustment
« Reply #1 on: June 26, 2008, 12:09:47 PM »
No dont think there is, the reason being is when you edit the programme you are in effect reloading it and Mach regenerates the toolpath.
« Reply #2 on: June 27, 2008, 05:54:10 PM »
thanks for your answer, can some1 confirm it?
thanks
vmax549
« Reply #3 on: June 27, 2008, 06:09:50 PM »
yes
