Hello
Guest
it is
December 26, 2024, 07:38:53 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
z-axis problem
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: z-axis problem (Read 17139 times)
Chaoticone
5,624
Precision Chaos
Re: z-axis problem
Reply #10 on:
June 30, 2008, 08:42:56 PM »
Yup, Overloaded is right I bet. Do you have any scaleing values in your scaleing dros? Small dros just beside the axis dros on the program run screen. Should be 1:1.
Logged
If you could see the things I have in my head, you would be laughing too.
euro
14
Re: z-axis problem
Reply #11 on:
June 30, 2008, 08:51:20 PM »
i bet i do never notice ill have to run to the shop and see the people where i bought made there own screen so it is diferent than the default screens thanks for your help ill get back and post my findings
Logged
euro
14
Re: z-axis problem
Reply #12 on:
June 30, 2008, 09:25:20 PM »
no i dont have scaling dros is there somewhere in mach where i can scale from
Logged
Chaoticone
5,624
Precision Chaos
Re: z-axis problem
Reply #13 on:
June 30, 2008, 10:59:11 PM »
euro,
Can you post your xml files and your screen sets? I will look at those and try to find the problem.
Logged
Overloaded
4,922
Re: z-axis problem
Reply #14 on:
June 30, 2008, 11:06:21 PM »
You might enter a G50 in the MDI to be sure all scaling is cancelled and reset to 1:1, then try the move again.
RC
Logged
euro
14
Re: z-axis problem
Reply #15 on:
June 30, 2008, 11:08:29 PM »
thanks a lot for your help i got a hold of tec support and he thinks i must of typed in 2000 instead of 20000 steps under moter tunning ill double chek that in the morning agian thanks
Logged
Overloaded
4,922
Re: z-axis problem
Reply #16 on:
June 30, 2008, 11:13:24 PM »
Brett had that nailed for you in the beginning......I didn't realize you had changed stuff.
RC
Logged
euro
14
Re: z-axis problem
Reply #17 on:
June 30, 2008, 11:29:59 PM »
the problem started when i ran a file i got from the vectric forum could it had been what was in the g codes that changed the settins i know i didnt
Logged
euro
14
Re: z-axis problem
Reply #18 on:
June 30, 2008, 11:36:49 PM »
brett also mention microsteps that i might have changed it where do you find the settins for the microsteps so i can also check that thanks
Logged
Overloaded
4,922
Re: z-axis problem
Reply #19 on:
June 30, 2008, 11:55:07 PM »
Follow these steps..if your steps per is 2000, make it 20000 then be sure to save, then try the Z move again.
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
