Hello Guest it is September 27, 2026, 03:28:38 AM
Author Topic: Rapid speed & Cutting Speed (Feedrate)?  (Read 13534 times)
« on: August 02, 2008, 01:25:41 PM »
Hi Guy, is anyone Know, in Mach3 can be set in different Axis in Rapid Speed.??
1) Can i Set Rapid Speed Faster or Slower in a different Axis?
2) Can i Set my Cutting Speed (FeedRate) Faster or Slower in a different Axis?
i need Faster Rapid Speed & Slower Cutting Speed (FeedRate)
Anyone can Help????
Re: Rapid speed & Cutting Speed (Feedrate)?
« Reply #1 on: August 02, 2008, 01:59:15 PM »
Rapid speed is whatever velocity you have set in motor tuning for that axis, you can set a slow Jog speed as a percentage of that, press the Tab key on your keyboard and you will see a pop out window. If you set the Slow Jog you can over ride this when jogging by pressing the shift key at the same time as you are jogging.
Cutting speed is set by the F word in your code, for example if you are in G94 mode (mm/min or inch/min) then F100 will be the speed the axis goes at when doing G1,G2,G3 moves. G0 moves will be at rapid speed. If you are in G95 mode F100 would be 100mm per revolution so be careful ;)
