Hello Guest it is September 19, 2026, 11:18:19 PM
Author Topic: Does any one have the datasheet for a HP HEDS-7500 Optical Encoder??  (Read 47683 times)
Re: Does any one have the datasheet for a HP HEDS-7500 Optical Encoder??
« Reply #1 on: August 05, 2008, 04:47:08 PM »
Have a look in the links section, electronics, Datasheet catalog I think it is. Hopefully you can find it there.
« Reply #2 on: August 05, 2008, 07:02:20 PM »
No luck.  I managed to stump google on this one.  Any other ideas?
« Reply #3 on: August 05, 2008, 10:58:05 PM »
Oh man, sorry.   :(  Have you tried contacting the manufacturer?
« Last Edit: August 05, 2008, 11:26:09 PM by Chaoticone »
« Reply #4 on: August 05, 2008, 11:24:58 PM »
I think that is the next step
« Reply #5 on: August 06, 2008, 09:00:27 AM »
HAHAHAHA, that is who I bought them from.  He does not have the data sheet.
« Reply #6 on: August 06, 2008, 09:05:21 AM »
Posted by: LAWAUTO
Insert Quote
Maybe this can help! Try to contact the seller for more info.
Good luck, Lou
http://cgi.ebay.com/HP-HEDS-7500-OPTICAL-ENCODER-ROTARY-PULSE-GENERATOR-CNC_W0QQitemZ320282415373QQihZ011QQcategoryZ4660QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Doing some testing. This was originally posted by LAWAUTO. All is well, just testing somehting.
« Reply #7 on: August 06, 2008, 09:11:14 AM »
I know they are running 5V TTL compatible logic.  From there I should be able to reverse engineer the rest.  I bought one extra to blow up :-).  What does Mach require form an encoder?  Just a square wave?
« Reply #8 on: August 06, 2008, 09:15:31 AM »
yes just 5v square wave A and B channels.
What are you going to use the encoder for? if its your motors then it doesnt matter to Mach anyway as they go to your servo drives.
« Reply #9 on: August 06, 2008, 09:36:47 AM »
My cnc is stepper based, and home brew.  It likes to jam.  I am hoping if I add the encoders I can help solve that issue.
