Hi Sauli
How did you make out with your spindle drive configuration,did you get it to
work o.k.? I am doing the same thing with a 2.5 hp treadmill motor and a 200 volt
uhu drive.I can get it to run very close to the programmed rpm but ,it doesent like
to reverse very good,which it will need in order to rigid tap.
Thanks Rick
