the following are some of my observations and troubles with a couple of the wizards -
the OD groove wizard crashed M3 on two systems -
one has v84.000 and the other 001
one time it crashed so badly on the brand new system that I got with my Sherline lathe, that I couldn't even reboot. It left a process running that I could not quit from the task manager. Tried to reboot - but then it would not close down I guess because of the M3 process that would not unload. Had to reset the system. Hate to do that to Windows.
The id arc seems to want to cut into -X by .1" -- I went over that one a dozen times trying to figure out why it wouldn't work like I thought it should. Reset home and x/z 0 several times - still goes negative -- even the code says -X.1??"
any help out there? Suggestions? Work Around?
thanks -
ds\
