I need help.
I am using the MACH3 3,041 in all reversals of direction (in any axis), but only for a sense (+), when the signal from the DIR has to go down, my servo motor account 1 pulse to the wrong side, then again from the right side, losing 2 pulses, which in my case = 0.002 by the pulse = 0.004mm in total.
When I turn the output STEP and DIR to perfect it, but the step can not pass a certain frequency, or at least when greater frequency, (high speed), my driver not to recognize.
I use Servo Drives Panasonic and a Bob C11G of CNC4PC - Duncan.
My driver has inputs with opto.
I already tried the following:
. Increase the time of "STEP" until 20us, not resolved, the system is held in high speeds.
. Increase the time of "DIR" until 20usĀ not resolved.
. Other versions of MACH3 until the "View 2.00", not resolved.
Please make any ideas for me?
I think the time reversal of direction is not large enough to make my driver a reversal. But a sense works, how it happens?
Is there any parameters possible to adjust the difference between Step and DIR?
What is the difference between the first "DIR" pulse and the first "STEP"
You can adjust this parameter?
Thank you.
