Hello Guest it is September 26, 2026, 02:40:55 AM
Author Topic: x and y axis not working properly....PPPPPLLLLLEEEEAAASSSSSEEEEE help!  (Read 25018 times)
Re: x and y axis not working properly....PPPPPLLLLLEEEEAAASSSSSEEEEE help!
« Reply #10 on: September 23, 2008, 11:57:09 AM »
Bit confused as where you measured, was it at the drive?
If it was then looks like its either a drive or motor problem, try swapping the drives around and see if the problem follows the drive.
« Reply #11 on: October 01, 2008, 07:22:46 AM »
hi hood.
yes the problem followed the drive.   i took the drive apart and cleaned all the dust out of it and now it works fine.  i work in a wet environment so i think some moisture was getting into the drive.  combine the moisture and the dust and i think it was shorting out.
thanks for the help!!!
dave
« Reply #12 on: October 01, 2008, 02:51:18 PM »
excellent news :)
