Hello Guest it is October 11, 2026, 03:40:58 PM
Author Topic: Spindle output not function  (Read 14927 times)
« on: September 19, 2008, 11:27:01 AM »
I to all can´t figured why spindle relay don´t start when i press spindle button and m3 or m5 function. At ports and pins i have set output enable port 1 pin number 2 and in the Spindle Setup tab i unchecked Disable Spindle relays. At the diagnostics everything work fine. The only way that i put it to work is set the Active low on at the outputs tab , but then the only way to stop it is cut the power.Any suggestion?
  Thanks in advance
Marco
Offline Kristin D
  •  203 203
  • Take that you LazyCam, next stop the glue factory!
Re: Spindle output not function
« Reply #1 on: September 19, 2008, 12:31:15 PM »
Marco,
Can you attach a sketch of your relay circuit & part number or relay type, it would help to answer your question.
Kristin
« Reply #2 on: September 20, 2008, 08:59:41 AM »
Problem solved! It was a malfunction in the Cmos of BreakoutBoard.
Thank you any way
