Helloo,
I have very big problem.I have 400 watt delta ac servo .I setup my system 1000 pulse for 1 mm and when I write G0 X+1 then G0 X0 .The servo dont get back start position.The servo company said that the mach3 not produce same pulse count.And I looked the servo online watch system when I said go +1 mm produce 982 pulse then go the 0 (start point) it produce 943 pulse so 39 pulse miisng?
What is the problem? Ground problem or what? I am using shermil 1/2.I have direct parallel interface card for direction and step
Please give me advice
