If you home the machine the X Y and Z will be zeroed in Machine coordinates. If previously you have moved to your workpiece and pressed the zero button at the side of each DRO you have set up a work offset, you can verify this by pressing the machine coords button this will display the machine coords which will be the distance you have just moveed each axis, press the button again and you will be back to displaying your work offset coordinates (x0,y0z0)
If for any reason you have lost position you just home again and then when you press the Go to Zero button it will move back to your Work offset X0Y0Z0.
When you shut Mach down it will probably ask if you want to save the work offsets, if you choose Yes then the next time you switch on you Home then you can go back to the same X0Y0Z0 in work offset.
