Hello
Guest
it is
September 01, 2024, 02:39:02 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mirror image when engraving, why?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mirror image when engraving, why? (Read 5345 times)
replicaprops
36
on:
June 15, 2006, 06:53:02 PM »
I never noticed this untill the other day and for the life of me I cant figure out how to fix it.
I am engraving and everything is a mirror image. Even in the engraving wizard that comes with Mach3.
I tried reversing the servos in the homing limits tab and all it does is flip the engraving so its upside down. but its still a mirror image.
Any suggestions?
((((EDIT))))
In an effort to out do my sself in stupid mistakes, I just realized when I reversed the servos I reversed both x and y. It was not until just now that I realized that was my mistake. I just now reversed only the x and fixed the problem. Maybe if this topic comes up agin my post will help others deal with brain farts like mine.
Last Edit: June 15, 2006, 07:07:45 PM by replicaprops
Logged
Brian Barker
3,860
Re: Mirror image when engraving, why?
Reply #1 on:
June 15, 2006, 07:26:50 PM »
Good job getting that fixed! nice to see that you kept working on it!
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
ilkleyal
19
Reply #2 on:
May 16, 2012, 12:39:38 PM »
Bit of an old post but it helped me today so shows the importance of searching.
I had a mirror image of parts which I had noticed when running an odd shaped profile. Tried to engrave text to confirm and sure enough, Y axis needed reversing.
I knew I had to reverse something and this post explained in under a minute where the problem lie
Just for info.
Al.
Logged
joeqman
5
Reply #3 on:
May 28, 2012, 01:48:47 PM »
Well I am having the same problem, by the way Im a newby. Please be patient with I have to learn some terminology.
I built a Solsylva plan machine. dual X drive with a 1600 oz motor. My Y & Z are driven by 425 oz..
I did have to initially have reversed Y and Z drives as they traveled in the wrong direction. Did changing the motor direction do some to change the Gcode
The file looks correct in the preview window but mirrors the cut.
Any steps I should take? I afraid to do some thing that will only cause me more frustration.
Joe
Logged
joeqman
5
Reply #4 on:
May 29, 2012, 08:42:55 PM »
update!
got it figured out. a newb mistake. I was homed on the opposite side of where I should have been.
Had to walk away from it for a couple of days
Sorry for wasting anyones time
Logged
Tweakie.CNC
9,228
Super Kitty
Reply #5 on:
May 30, 2012, 08:22:59 AM »
Hi joeqman,
I am pleased you got it sorted.
Never worry about wasting anyone's time - your solution will, in turn, help someone else and that is the way it goes.
Logged
joeqman
5
Reply #6 on:
May 30, 2012, 07:28:15 PM »
Thanks Tweakie,
I have a lot of time in this project, and just didnt know where to turn too.
Logged
Print
Pages:
1
Go Up
« previous
next »
