Hello Guest it is December 26, 2024, 05:03:54 AM
Author Topic: Slider and touc hscreen problem  (Read 5873 times)
« on: June 27, 2006, 03:53:01 PM »
Hi, I have use a touch screen for a while now with Mach3 1.84
and now I downloaded the latest version 1.90.053 to try the slider.
But with my touch screen the slider for feed rate always change
back to 250% even if I use the mouse instead of touching the screen.
And when I try the same without the touch screen then the slider stayed as
I left it.
Have anyone tried the slider with a touch screen and got it working?
Roger
Re: Slider and touc hscreen problem
« Reply #1 on: June 27, 2006, 07:22:48 PM »
I will pass this on to Art :)
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: June 29, 2006, 03:59:38 PM »
Hi all,
my mistake, sorry about that.
I had the key grabber activated and one of the joystick axle was set to adjust
feed rate.
Sometimes I got very tired if myself.  :-[
Sorry again that I disturbed you guys.
Roger
« Reply #3 on: June 29, 2006, 07:26:33 PM »
No problem!  I have done the same thing :)
www.machsupport.com
