Hello Guest it is October 02, 2026, 02:11:54 PM
Author Topic: Mach3 file open improvement  (Read 10687 times)
« on: November 01, 2008, 11:31:31 AM »
Mach is parses the code pretty slow when you open a file. I'm guessing it parses the code for gcode errors and finds program extrema (not correctly I might add).
I would like to be able to turn off the program extrema calculation method or see it rewritten using RegEX so that it parses faster.
Brian
