Hello Guest it is September 15, 2026, 05:41:20 PM
Author Topic: Activating macros with more than one oem triggers  (Read 68985 times)
Re: Activating macros with more than one oem triggers
« Reply #30 on: November 12, 2008, 06:50:20 PM »
I have it slightly different,
as when you first start mach ,and even when you load the brain
it fires of the Z zero macro (without a button push)
Thats why I thick these coloured boxes have the answer
That is ,this trigger is somehow active.
I have tried a different input  I will  now try another trigger,
which by the way how do you edit a brain?
Regards
Whatda?
Offline Greolt
  •  956 956
« Reply #31 on: November 12, 2008, 06:56:17 PM »
Open it up in "Brain Editor"
Five minuets playing around with that and you will know more than I do about it.  ;D
Greg
« Reply #32 on: November 12, 2008, 07:02:26 PM »
Yes I found the editor
and tried a different trigger,
still the same,
I will try the same input pin and trigger thats on the xy
see if I can fault find that way.
 thanks
Regards
Whatda
Offline Greolt
  •  956 956
« Reply #33 on: November 12, 2008, 07:06:43 PM »
Make sure with you trying different things that you don't get something wrong in "Ports and Pins"
Don't want two inputs on one pin or something like that.
Greg
« Reply #34 on: November 12, 2008, 07:18:31 PM »
I reversed the triggers around ,just in  the brain same results only with the other macro.
Is there any chance you could write a brain without the timer function and I`ll will check it out.
Regards
Whatda?
« Reply #35 on: November 12, 2008, 07:30:49 PM »
I made up a simple brain IE trigger ------- Userled .
and its working find and not firing of the macro when
I start mach.
Not sure how I go about implementing the and or functions
with axis movement and the spindle on.
Will look into it and come up with some trial and ERROR stuff.,
Regards
Whatda?
Offline Greolt
  •  956 956
« Reply #36 on: November 12, 2008, 07:32:13 PM »
OK here it is.  You could write it in a couple of minutes.  It would be a good exercise to do.  :)
I repeat though there is no point having a brain at all if not wanting the timer.
It will all be simpler to do in the macropump with the exception of the switch delay.
Greg
« Reply #37 on: November 12, 2008, 07:46:50 PM »
Thanks For that Greg,
What I am trying to do is isolate the problem.
This will probably do for now though.
Thanks for all your help.
Is there any manuals on Brain,somewhere,
I can study up on,
I just had abit of ago then,but couldnt find
where you found/inputed ( and . and input.)
The rest  seems all straight forward ,,,sort of.
Regards
Whatda?
Offline Greolt
  •  956 956
« Reply #38 on: November 12, 2008, 07:56:45 PM »
There are a couple of videos.  Have a look at them.
Mostly you are going to learn more by poking around with it.
Greg
« Reply #39 on: November 12, 2008, 08:01:02 PM »
I think I found the problem,But Iam not sure how to fix it?
With that last brain you sent ,the z zero routine activates after
any  axis has been moved.
And every time you move a axis.
So somewhere in the and ,and input its getting into trouble.
Will keep trying.
Must go and have some Lunch.
Regards
Whatda?
