Hello Guest it is March 13, 2025, 01:10:01 PM
Author Topic: Activating macros with more than one oem triggers  (Read 34945 times)
Offline Greolt
  •  956 956
Re: Activating macros with more than one oem triggers
« Reply #40 on: November 12, 2008, 09:36:51 PM »
Well after you said that I raced out to the shed and tried it.
Apart from it having no delay (very quick) it worked fine on both macros.
I'm thinking you may have a dicky input.  Are you getting noise on it?
Have you tried the filtering in the SmoothStepper plugin?
Greg
« Reply #41 on: November 13, 2008, 12:22:48 AM »
Look in your Ports and Pins under Inputs it sounds to me like you have One of the OEMTRIGGRS set to "Active High", and the other to "Active Low", OR, your actual swithes one may be N/C and the N/O.
scott
« Reply #42 on: November 13, 2008, 02:02:05 AM »
YES!!
Sorry to drag you guys trough all of this
But you are right one of the pins had to be
active High.
If I had known a bit more about Brains
I could have found that myself ,Sorry.
I had a felling that it was why the coloured boxes were
different in the initial inputs to brains??and
of course they are the same now,(no registered inputs).
Anyway working like a charm now,Thanks so much for your help.
NOw on to the next problem, No *********x in the fridge ,Bugger!
Regards
Whatda?
Offline Greolt
  •  956 956
« Reply #43 on: November 13, 2008, 03:08:23 AM »
Glad it is going for you now Whatda.
Think about putting those time delays back in won't you.   ;D
Greg
« Reply #44 on: November 13, 2008, 03:09:56 AM »
Already in, and working like a treat,Thankyou
Whatyda?
