Hello
Guest
it is
August 31, 2024, 08:17:41 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Help getting set up
« previous
next »
Print
Pages:
1
2
3
4
5
6
Go Down
Author
Topic: Help getting set up (Read 28763 times)
Carnoustie, Scotland
Re: Help getting set up
Reply #40 on:
November 15, 2008, 06:06:40 PM »
This is the layout of the pins on the back of your computer.
Logged
Rob27
25
Reply #41 on:
November 15, 2008, 06:11:47 PM »
I am getting 5V dc, between the pins when jogging on the x axis.
Logged
Reply #42 on:
November 15, 2008, 06:13:53 PM »
Does it go to zero when you jog the other way?
Logged
Rob27
25
Reply #43 on:
November 15, 2008, 06:19:42 PM »
No it does not go back to zero, it stays at 5v in either direction.
Logged
Reply #44 on:
November 15, 2008, 06:25:29 PM »
Ok well if thats the case and you have not changed any pins since you attached your xml then it seems like your parallel port is not working correctly. Just double check in device manager that the port address is correct, if it is then looks like your port is bad
You could get yourself a PCI port if that is the case, they are usually not too expensive.
Last Edit: November 15, 2008, 06:27:05 PM by Hood
Logged
Rob27
25
Reply #45 on:
November 15, 2008, 06:35:11 PM »
Well, when I checked the pins, most said 5v dc. When I went the other way with the jog, the voltage did not change from 5 volts...
Logged
Reply #46 on:
November 15, 2008, 06:43:24 PM »
Only the pins you have set up for Direction pins will change when you jog and only then when you jog the correct axis. For example in the xml you attached you have pin 3 set for X so if you jog the X it should change between 5V and 0V when you change directions. Same for pin 5 if you jog the Y and pin 7 if you jog the Z. Pins 2 4 and 6 should show 0v when still and maybe around 1V when jogging their respective axis.
Logged
Rob27
25
Reply #47 on:
November 15, 2008, 06:55:43 PM »
Alright, so I got that to work.. It will read 0, and around 3.25 volts dc between pin 3 and 25, and 5 and 25... Alright, its not the PCI card, I feel pretty confident about that...
Logged
Reply #48 on:
November 15, 2008, 07:01:18 PM »
Ok so next thing to do is put the cable on the computer and disconnect from the C10 and do the same checks, some parallel port cables are cross overs so the pins do not correspond and also some do not have all the pins connected.
If that checks out OK then put the cable back on the C10 then do the same procedure and this time check on the C10s connections to your drives Dir inputs.
Logged
Rob27
25
Reply #49 on:
November 15, 2008, 07:05:00 PM »
Actually, I did the checks with the cable attached to the computer, and read the voltages from the the end of the cable.
Logged
Print
Pages:
1
2
3
4
5
6
Go Up
« previous
next »
