I am new to CNC'ing and I am
almost ready to make the first cut. I have read the tutorials about homing/referencing, but I am confused about positioning the tool to begin the cut. I will be using a 1/8" cutter to route a profile in 1/8" thick material (cut out) and drill holes thru the material. The material will rest on a 3/4" MDF backer board. I have put my drawing in LazyCam and created the code. It's not a complicated part, it's a chassis for an RC car. There are no arcs, mostly right angle, angle and straight cuts.
1. Does it matter how the bit is positioned in the router i.e. how much of the cutter is sticking out for want of a better word
2. Do you allow for the backer board and the thickness of the material, if so where and how
3. After homing do you jog the tool to the starting point and then do a REF/ALL command on the screen
4. I am just not clear on how the tool knows where to start the cut, and how to define that. It will affect the depth of the cut I set in LazyCam
I do not have access to my Gcode right now I will post later if needed.
Thanks for all your help,
John
