Hello Guest it is December 21, 2024, 12:09:55 PM
Author Topic: What´s the biggest machine using Mach3?  (Read 8829 times)
« on: November 28, 2008, 05:14:46 PM »
Hello, I just wonder, what is the biggest machine using Mach3?
Jorge
Re: What´s the biggest machine using Mach3?
« Reply #1 on: November 28, 2008, 05:42:28 PM »
Not sure, depends how you want to define biggest.  I have a Churchill Computurn Lathe, its about 3000 KG and have attached the capacity below.
« Reply #2 on: November 29, 2008, 08:07:53 AM »
Offline N4NV
  •  398 398
« Reply #3 on: November 29, 2008, 11:00:10 AM »
My Yamazen mill weighs 4,500 pounds and my Hardinge CHNC weighs 5,000 pounds (but half of that is the stand.)
Vince
« Reply #4 on: November 29, 2008, 07:08:25 PM »
Ive done a lathe that will turn 40" dia railroad wheels, and about 10 feet between centers. I also claim its the oldest lathe to be converted- built about 1892
see http://www.machsupport.com/forum/index.php/topic,5654.0.html
« Reply #5 on: November 29, 2008, 07:12:21 PM »
« Reply #6 on: November 29, 2008, 07:15:24 PM »
Ron,
 whats the rigidity like, tool seems a bit precarious perched away up there but suppose its taking fairly light cuts on those wheels?
« Reply #7 on: November 29, 2008, 09:01:43 PM »
The big lathe only has a 5hp motor on the spindle, so that really limits our cuts. The tool is actually on 2 compound slides we stacked up. It only covers about 6" is either axis, but for railroad wheels thats all we need. A wheel has a rather complicated profile of tapers and filets, so the cnc really helps, doing them manually was a real pain.
« Reply #8 on: November 29, 2008, 09:48:50 PM »
ok,
   Here is the OMAG Granite mill I made the control for, 2KW AC Servos, 20hp spindle, when you click the link
loot at "Reply #1" third picture down. There is a Full Grown 6' man standing on the Mill Table.......
Mabey not the bigges, but envelope on it is 20' in the X, 12' in the Y, 6' in the Z
Has Air, vacuum, and Hydrolic systems, plus the regular Electronic stuff........
Line:   http://www.machsupport.com/forum/index.php/topic,5536.0.html
scott
