Hello
Guest
it is
December 26, 2024, 07:28:28 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
ports and pins
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
Go Down
Author
Topic: ports and pins (Read 45644 times)
Carnoustie, Scotland
Re: ports and pins
Reply #80 on:
December 23, 2008, 11:38:18 AM »
Well thats certainly weird, I downloaded and installed it on a laptop just to see and it was fine for me, dont know what else to suggest.
Logged
rabphxaz
115
Re: ports and pins
Reply #81 on:
December 23, 2008, 06:48:17 PM »
Hood,
I had a computer pro come over and he has determined that the crv files that are being generated by VCarvePro are not text files. We loaded one of Mach's test files scorpion.tap and it reads as Gcode. The computer guy said that this *.tap file is a text file.
How do I turn a *.crv file into a *.tap (gcode) text file
or how do I export or save from vcarve to a *.tap file
or how do I open a *.crv file or a *.eps file or a *.ai or a *.dxf file from mach 3. These are all file formats that vcarve exports to.
Am I supposed to run a third program that turns *.crv files or *.ai or *.dxf or *.eps into a *.tap file
What am I missing?
Please help.
Logged
Re: ports and pins
Reply #82 on:
December 23, 2008, 07:06:55 PM »
The file you attached was fine for me but it had a txt extension. Have you tried simply changing the file extension? V Carve should allow you the option of file extension to post with.
Logged
budman68
2,352
Re: ports and pins
Reply #83 on:
December 23, 2008, 07:22:17 PM »
When you save a finished toolpath in VCarve pro, it saves it as a *txt file. In order to open this in Mach 3 you need to hit the drop down box (File Type) and choose either "*txt" files or "all files" and then your VCarve txt files will show up and allow you to open them.
Logged
Dave->
rabphxaz
115
Re: ports and pins
Reply #84 on:
December 23, 2008, 07:40:30 PM »
Thanks, Dave, I'll give that a try. And thanks also, Hood, for all your effort.
Bob
Logged
Print
Pages:
1
2
3
4
5
6
7
8
9
Go Up
« previous
next »
