Hello Guest it is September 30, 2026, 05:14:33 AM
Author Topic: Mach 3 Freezes after 1024 lines of code?  (Read 14577 times)
b0gh0s
« on: July 13, 2006, 09:46:49 PM »
For some reason Mach 3 won't load more than 1024 lines of code.  I have licensed it properly and have been using it successfully for a while.  All controls seem to work correctly.
When I try to load a larger file it loads and shows all lines/arcs/etc up to the 1024th line of code.  When I try to scoll down through the code, as soon as I see line 1024 it freezes that window and just keeps repeating the last few lines of code.  When I check the text file with the code in it, everything seems kosher.
Any ideas why the heck Mach3 is doing this?  Is there a files size limitation?
ynneb
Re: Mach 3 Freezes after 1024 lines of code?
« Reply #1 on: July 13, 2006, 10:15:13 PM »
Upload your code and we can see if its a problem with your code or mach.
Thanks.
